Старый 22.06.2015, 11:11   #1
emeadaxsupport: SEPA Payments processing date is in YYYY-MM-DD date format
Источник: http://blogs.msdn.com/b/axsupport/ar...te-format.aspx
When generating SEPA payments you might to your surprise have noticed that the processing date is not in the commonly used European format(DD-MM-YYYY). If you the date as DD-MM-YYYY in the payment processing dialog, you get an "Processing date should be in format YYYY-MM-DD" when you generate the SEPA file.
The reason for this behavior is by design. Dynamics AX follows the SEPA schema definition established by the European Payments Council, and here it is specified to use the international date format standard of ISO 8601 standard, which formats the date as YYY-MM-DD
sepa
emeadaxsupport: Generic ISO20022 Credit Transfer format is available for Austria for non-SEPA payments in Microsoft Dynamics AX 2009 Service Pack 1 Blog bot DAX Blogs 0 25.06.2014 19:12
emeadaxsupport: Cumulative SEPA credit transfer and SEPA direct debit update for Austria direct debit specific country format and update COR1 mandate scheme in Microsoft Dynamics AX 2012 R2 has been released Blog bot DAX Blogs 1 16.12.2013 18:16
emeadaxsupport: Cumulative SEPA credit transfer and SEPA direct debit update for Austria direct debit specific country format, update COR1 mandate scheme and changes in MT940 file import format functionality in Microsoft Dynamics AX 2012 has been rel Blog bot DAX Blogs 0 13.12.2013 20:11
emeadaxsupport: Cumulative SEPA credit transfer and SEPA direct debit update for Austria direct debit specific country format, update COR1 mandate scheme and changes in MT940 file import format functionality in Microsoft Dynamics AX 2009 SP1” has bee Blog bot DAX Blogs 0 12.12.2013 13:11
Часовой пояс GMT +3, время: 08:07.
