Старый 24.06.2015, 14:11   #1
emeadaxsupport: Error executing code: FormRun (data source) has no valid runable code in method 'new' when trying to edit Project workflow
Источник: http://blogs.msdn.com/b/axsupport/ar...-workflow.aspx
If you go to Project management and accounting > Setup > Project Management and accounting workflow and you select any workflow and hit Edit and you get an error stating
"Error executing code: FormRun (data source) has no valid runnable code in method 'new'
Try to to locate the form that is failing to launch in the AOT. In this case it will be 'WorkFlowEditorHost'. Make a small change to the form, compile it and then delete the change and recompile.
Try now to see if you are able to edit the workflow after this.
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
ax-erp: Code that must not be put in data source active() method Blog bot DAX Blogs 2 27.04.2012 18:44
Часовой пояс GMT +3, время: 23:31.
