Старый 04.12.2015, 09:12   #1
mfp: X++ in AX7: Finally and using
Источник: http://blogs.msdn.com/b/mfp/archive/...and-using.aspx
Finally, X++ got support for the finally statement. It has exactly the same semantics as in C#. This means that you can now write:
try
catch
finally
The contents of the finally block is guaranteed to be executed - regardless of exceptions or transactions. It is typically used to clean up any usage of none-managed resources. And to make that construct even cleaner, you can use the using keyword for types implementing the System.IDisposable interface.
using(var myObject = new MyObject())
myObject.someMethod();
This is short hand for:
var myObject = new MyObject();
try
finally
myObject.Dispose();
One more thing…
Just like in C# the using statement can also be used to avoid providing fully qualified names when referencing .NET types. This means I can implement MyObject like this:
using System;
class MyObject implements IDisposable
public void Dispose()
THIS POST IS PROVIDED AS-IS AND CONFERS NO RIGHTS
Старый 04.12.2015, 10:07   #2
AndyD is offline
AndyD
КОРУС Консалтинг
2,560 / 2499 (89) +++++++++
Вот за finally хотелось бы сказать спасибо)
Axapta v.3.0 sp5 kr2
Старый 04.12.2015, 12:45   #3
Link is offline
Link
Британский учённый
Аватар для Link
568 / 523 (19) +++++++
Записей в блоге: 9
О, наконец то using добавили!
Людям физического труда для восстановления своих сил нужен 7-8 часовой ночной сон. Людям умственного труда нужно спать часов 9-10. Ну а программистов будить нельзя вообще.
ax7, mfp, x++
Часовой пояс GMT +3, время: 21:49.
