Старый 18.12.2015, 13:11   #1
Dynamics AX Sustained Engineering: Provide feedback on your AX 2012 R2 and R3 deployments
Источник: http://blogs.technet.com/b/dynamicsa...ployments.aspx
5 minutes of your time could help us serve you better
(This Survey should be completed by the AX Technical Leader within your organization)
Please take 5 minutes (for each survey) to share information about your existing AX 2012 R2 and R3 deployment and your update and upgrade plans*.
We will be using the results of this survey to understand our current AX2012 R2 & R3 customers infrastructure and Cumulative Update needs. We will also be using these results to build the AX2012 R2 compatibility roadmap.
We are committed to improving your experience and continue to turn your feedback into action.
Click below links to provide your feedback
AX 2012 R2 feedback link
AX 2012 R3 feedback link
Survey Length:
Time to complete each survey is approximately 5 minutes
*Update : Moving within same AX versions (For example moving from AX 2012 R2 CU 8 to AX 2012 R2 CU9)
*Upgrade : Moving to higher AX version (For example moving from AX 2012 R2 to AX 2012 R3)
Dynamics AX Sustained Engineering: Announcing support for Team Foundation Server 2015 with AX 2012 R2 and R3 Blog bot DAX Blogs 0 21.11.2015 20:15
axperf: Multiple new Benchmarks released: Microsoft Dynamics AX 2012 R2 Multiple Retail Workloads, Microsoft Dynamics AX 2012 R3 Financial Benchmark, Microsoft Dynamics AX 2012 R3 Day in the Life Benchmark for Retail and Distribution Blog bot DAX Blogs 5 13.01.2015 14:26
Dynamics AX Sustained Engineering: AX 2012 R3 Cumulative Update 8 - FAQ Blog bot DAX Blogs 1 24.11.2014 23:57
Dynamics AX Sustained Engineering: Announcing Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 20.11.2014 04:16
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Часовой пояс GMT +3, время: 13:39.
