Старый 14.03.2016, 22:11   #1
organicax: Basic process of handling item requirement on a project.
Источник: http://organicax.com/2016/03/14/basi...-on-a-project/
If you are working with projects then you might want to consume items and bill them through your project. You can do this with an item requirement. Essentially this is a sales order that you manage from your project. From there you can create the pick and invoice. Now the pick will be handled if you do small amount of items by a paper process and could have a warehouse or inventory team involved for larger scale operations. It’s important to note that if you are looking at using the advanced warehouse in R3 then you will need to be using CU10. The overview below is CU9 for a simple process without warehouse.
Here is a quick walk overview.
AX2012 R2 CU9.
Cheers
Lachlan
Filed under: Project management and accounting
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Khue Trinh: Create Intercompany PO from Project item requirement Blog bot DAX Blogs 0 09.11.2010 19:04
Khue Trinh: Create Intercompany PO from Project item requirement Blog bot DAX Blogs 0 29.09.2010 12:05
Часовой пояс GMT +3, время: 21:57.
