Вернуться   AXForum > Microsoft Dynamics NAV > NAV: Прочие вопросы
Старый 25.11.2005, 22:18   #1
Will help you to find and remove unused Global and Local variables. You can simultaneously search in many objects (it is desirable that the size of the Text File was no more than 10 Mb).
It can be used in versions 3. and above.
Here results of search in a database NAV3.70W1
• Table (linked to Unused Variables 370W1Tab.htm)
• Form (linked to Unused Variables 370W1 Form.htm)
• Report (linked to Unused Variables 370W1 Rep.htm)
• Codeunit (linked to Unused Variables 370W1 CU.htm)
Working method:
• Export objects in the form of the Navision Text File.
• Run Form 70100 "Unused Variables".
• Specify the path of Export File.
• Click the Variables - Search Unused.
http://mibuso.com/dl.asp?FileID=537&Type=file
Часовой пояс GMT +3, время: 15:22.
