Вернуться   AXForum > Microsoft Dynamics NAV > NAV: Прочие вопросы
Старый 12.12.2005, 15:39   #1
This is sample Microsoft Navision Process Documentation. I've used Use Case Descriptions and Flow Diagrams (UML Activity Diagrams).
To standard Use Case Descriptions I've added links to setup options, locked tables and used global variables (see folder 'Screen Shots').
Each Use Case has its description with Main Success Scenario, Extensions and Variations (see folder 'Use Case Descriptions'). There is also Flow Diagram for each Use Case (see folder 'Flow Diagrams'). You can use Animation option to better understand what happens in the process (see folder 'Flow Animation').
I will appreciate your feedback. Would such documentation be helpful to you? Should I document other processes? Please send me an email to borut@navitools.com or visit www.NaviTools.com.
http://www.mibuso.com/dl.asp?FileID=540&Type=file
Старый 12.12.2005, 18:21   #2
IGG is offline
IGG
Полазил по их сайту и так и не понял зачем эта приблуда. НУ есть там Database Designer
Часовой пояс GMT +3, время: 15:23.
