Старый 13.06.2016, 11:12   #1
palleagermark: Cross-company data sharing in AX7
Источник: http://www.agermark.com/2016/06/cros...ng-in-ax7.html
In Update1 a new data sharing feature has been added. You can use the feature to share simple group and reference data between companies in an AX deployment.
You can read more about the feature in the Microsoft Dynamics AX Wiki.
From a technical perspective, it is interesting to see how the setup generates triggers on the database to register changes and to replicate data. These also indicates the caveat; data is replicated on SQL level and AX business logic is not executed.
ax7, crosscompany, репликация
kurthatlevik: Master data concepts Blog bot DAX Blogs 0 18.02.2016 12:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using Excel to Copy Data from One Company to Another Blog bot DAX Blogs 0 19.07.2013 15:11
dynamicsaxtraining: Basic concepts Blog bot DAX Blogs 0 24.02.2012 07:12
Часовой пояс GMT +3, время: 17:18.
