Старый 19.07.2016, 20:11   #1
emeadaxsupport: Data Management: Missing Entities
Источник: https://blogs.msdn.microsoft.com/axs...sing-entities/
If you find that you are missing entities listed in the Data entities form, you can try the following steps. Run the following SQL Script: — — This source code or script is freeware and is provided on an “as is” basis without warranties of any kind, — whether express or implied, including without limitation... Read more
emeadaxsupport: Error during data import, when using multiple entities in one Processing Group that have different financial dimensions Blog bot DAX Blogs 0 26.11.2014 20:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Microsoft Dynamics CRM Team Blog: Data management for Activity Feeds entities Blog bot Dynamics CRM: Blogs 0 19.11.2011 04:20
Часовой пояс GMT +3, время: 21:43.
