Старый 08.08.2016, 22:13   #1
organicax: WMS Mobile device menu – Allow splitting of work
Источник: https://organicax.com/2016/08/08/wms...tting-of-work/
When working with the RF device on the mobile portal you might want to consider the workers ability to take stock when picking multiple full pallets, LP if you want to track it in the system. For example if they pick 2 LPs which might represent a pallet. Perhaps the equipment like a forklift can’t carry two pallets. So they have to make two trips. So they could either just do the two trips or if you want to have the worker update the system you could look at the option to allow splitting. For example you have the option to allow splitting of work on the mobile device menu.
Here is a quick overview.
AX2012 R3 CU10
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS Mobile device menu – display open work list user directed menus Blog bot DAX Blogs 0 07.08.2016 01:16
organicax: WMS Mobile Device menu – display open work list Blog bot DAX Blogs 0 06.08.2016 19:11
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Часовой пояс GMT +3, время: 21:20.
