Старый 10.09.2016, 02:25   #1
organicax: Basic Kanban rule setup – event automatic
Источник: https://organicax.com/2016/09/09/bas...ent-automatic/
When setting up Kanban rules in AX you have the three main replenishment strategies being fixed, scheduled, event. Each of different parameters that you can specify to control how the Kanban behaves. An event Kanban can be handy because it can be created when a sales is registered which is good in an environment where you are making to the order. In this example we’ll have a look at the basic flow of creating an event Kanban.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: WMS Packing compile of setup posts. Blog bot DAX Blogs 0 26.07.2016 16:11
organicax: Basic inventory unit setup for an item Blog bot DAX Blogs 0 30.04.2016 03:35
organicax: Basic constraint based configuration product and model setup. Blog bot DAX Blogs 0 28.03.2016 22:12
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
organicax: AX R3 Warehouse in manufacturing – end to end basic flow. Blog bot DAX Blogs 0 09.03.2016 16:11
Часовой пояс GMT +3, время: 11:12.
