Старый 20.09.2016, 10:11   #1
organicax: Create a fixed asset through a purchase order.
Источник: https://organicax.com/2016/09/19/cre...urchase-order/
In a previous post we had a look at the basic process of creating an asset manually. The procurement module and the fixed module are integrated in AX which means you can take on an asset from a purchase order which can save you time transferring information and if the parameters are configured correctly make sure that you capture assets instead of expensing.
Here is a quick overview.
AX2012 R3 CU11.
Cheers
Lachlan
Filed under: Fixed Assets, General ledger
organicax: Fixed Asset create from inventory Blog bot DAX Blogs 0 20.09.2016 10:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 22:11.
