Старый 28.09.2016, 09:11   #1
organicax: MES parameters – user badge ID
Источник: https://organicax.com/2016/09/27/mes...user-badge-id/
If you are looking at using the manufacturing execution system you might need to consider if you use the personnel number of a specific ID value in AX called the badge ID. You will need to factor the type of data that you have used for personnel ID’s for example I you have used letters and numbers and you plan to use the MES job registration form in the touch screen mode then the user won’t have the keys on the screen to enter it so you might have to use the badge ID.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: MES terminal – touch screen Blog bot DAX Blogs 0 28.09.2016 09:11
organicax: cXML punchOut user flow Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: Inventory parameters – last price history Blog bot DAX Blogs 0 22.04.2016 23:13
organicax: AR Parameters – Fulfillment rate, Fulfillment violation messages Blog bot DAX Blogs 0 11.04.2016 19:12
organicax: User preference for date, time and number format in the new Dynamics AX Blog bot DAX Blogs 0 15.03.2016 23:11
Часовой пояс GMT +3, время: 21:07.
