Старый 31.10.2016, 16:11   #1
organicax: LCS Data template to export data
Источник: https://organicax.com/2016/10/31/lcs...o-export-data/
There is a data template feature that you can find in LCS after you have configured system diagnostics on the environment. This will give you the ability to control an export from LCS based on the entities you configure. This could be used for example to export a set of data out of a template environment that you can move into another environment for example test or use as a basis for a new installation.
The data template supersedes the configuration manager because you can use the processing group that you define and therefore control the sequence of how the entities are executed.
Here is a quick overview or exporting with the template.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Data migration, Lifecycle Services
atinkerersnotebook: Creating a Product & BOM Import Template using the Data Management Tools within Microsoft Dynamics AX Blog bot DAX Blogs 0 24.09.2016 15:13
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
Часовой пояс GMT +3, время: 13:29.
