Вернуться   AXForum > Рынок > Microsoft и системы Microsoft Dynamics
Старый 02.11.2016, 11:36   #1
Dynamics 365 for Operations is now available to deploy and download
Источник: https://community.dynamics.com/b/msf...ally-available
См. также:
https://www.microsoft.com/en-us/dynamics365/home
За это сообщение автора поблагодарили: Alex_KD (2).
Старый 02.11.2016, 14:11   #2
Kashperuk Ivan: Announcement: Microsoft Dynamics 365 – Now generally available
Источник: http://kashperuk.blogspot.com/2016/1...s-365-now.html
Including Microsoft Dynamics 365 for Operations formerly known as Microsoft Dynamics AX aka Axapta The Fall release is here, meaning all sorts of goodies both in platform and application are now available for you to try out (You can actually do it for free for a week before you make a decision to buy). You can read the announcement by our CVP on the Microsoft Community blog To learn more about
Старый 02.11.2016, 14:11   #3
kurthatlevik: Try Dynamics 365 now
Источник: https://kurthatlevik.wordpress.com/2...amics-365-now/
Microsoft is currently holding an online virtual Dynamics 365 launch party and I’m happy to see that Microsoft is delivering as promised. Take a look at it here:
What Microsoft also have made available is a trial experience of Dynamics 365 for Operations. That is available here. What you get is an access to a 30 day multi-tendent trial experience, where basic testing can be taken place. In my case I got company number 037, and I cannot access other trial users company J
In this first release you will have limited access to 3 basic processes as defined in the trial experience task recording. You can try to navigate around, but you have very limited access to create customers/vendors/products etc. Important: This is NOT a full feature trial, and you NEED to follow the task guides as your guide to Dynamics 365.
Remember that Microsoft is constantly refining and improving the trial experience, and if you want a full-blown trial you need to contact a Dynamics 365 partner that can help you set this up. Later Microsoft will release additional trial experiences, and also support localized trial experiences. Other industry based trials are on the way, like Retail/POS experiences.
Check it out!
Старый 02.11.2016, 15:06   #4
Alex_KD is offline
Alex_KD
AxAssist
522 / 362 (14) ++++++
Так же VMки выложили на connect.
Целых две.
AxAssist 2012 - Productivity Tool for Dynamics AX 2012/2009/4.0/3.0
Старый 02.11.2016, 15:44   #5
Logger is offline
Logger
4,017 / 3301 (119) ++++++++++
Записей в блоге: 2
Подскажите как она соотносится с Ax7 ?
Старый 02.11.2016, 16:14   #6
технически это и есть ax7.2. просто название другое.
а вот как это соотносится маркетингово, по прайсу, по преемстенности обещаний и road map'ов...
я бы тоже хотел знать.
Старый 08.11.2016, 15:16   #7
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Сообщение от Alex_KD Посмотреть сообщение
Целых две.
Скачал себе версию с Windows Server 2016. Очень "тихая" в плане требований к памяти и работе с диском - просто отключил автозапуск для Management Reporter-а и можно спокойно работать в режиме демо\изучения. Ляпота
Миниатюры
-ТСЯ или -ТЬСЯ ?
Старый 08.11.2016, 15:28   #8
скачал, но еще не пробовал.
а где находятся база и iis applications? на этой виртуалке или в облаке?
есть ли в виртуалке Retail?
я скачал, но еще руки не дошли попробовать.
можешь вот такой скриншот сделать?
Миниатюры
Старый 08.11.2016, 16:00   #9
Vadik is offline
Vadik
Аватар для Vadik
Все так же как и в предыдущих версиях - IIS, SQL Server - все локально. Retail есть
Миниатюры
-ТСЯ или -ТЬСЯ ?
Старый 09.11.2016, 10:31   #10
DSPIC is offline
DSPIC
Боец
1,077 / 1243 (44) ++++++++
Вопрос: раньше для досутпа в AX7 был какой-то промо аккаунт, который впоследствии отключили. Есть ли подобный аккаунт сейчас? Как в систему пустить стороннего пользователя, в ознакомительных целях?
Старый 10.11.2016, 14:07   #11
MazterHan is offline
MazterHan
Можно немного подробнее откуда качали?
Старый 10.11.2016, 14:13   #13
https://ax.help.dynamics.com/en/wiki...ine-correctly/
https://ax.help.dynamics.com/en/wiki...pment-machine/
Старый 11.11.2016, 21:08   #14
Freeangel is offline
Freeangel
173 / 55 (2) ++++
У кого-нибудь получилось зарегистрировать нового пользователя как описано в инструкциях?
d365o, vm, демо-версия
Часовой пояс GMT +3, время: 17:41.
