Старый 08.02.2017, 07:18   #1
organicax: Changing a planned purchase to a RFQ
Источник: https://organicax.com/2017/02/07/cha...hase-to-a-rfq/
If you are working with planning and sourcing materials then you might on occasion have the need to use an RFQ to see if a product can be sourced differently from multiple suppliers. There is an option to change a planned purchase into a request for quote when reviewing the planned orders. This will then follow the RFQ and when a vendor is selected then a purchase order would be created from the RFQ.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing, Supply chain planning
organicax: Creating an RFQ from a purchase requsition Blog bot DAX Blogs 0 04.02.2017 10:16
Dynamics AX Sustained Engineering: KB 2973728 - When changing the vendor on a purchase requisition, and releasing the requisition to a purchase order, sales tax group and default dimensions are not updated on the purchase order and lines Blog bot DAX Blogs 0 29.06.2014 00:15
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 07:48.
