Старый 05.08.2017, 19:30   #1
daxrunbase: Fix Table and Field ID synchronization conflicts in AX
Источник: https://www.daxrunbase.com/2017/06/2...nflicts-in-ax/
It is a very common issue when we change metadata in a source/build environment incorrectly that the Production environment’s AX database field identifiers are getting out of synch from our Application Object Tree (AOT). This can typically happen during a code upgrade scenario (after applying a hotfix or a new ISV solution), or if a field/table has been deleted (because...
The post Fix Table and Field ID synchronization conflicts in AX appeared first on DAXRunBase.
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
Часовой пояс GMT +3, время: 08:22.
