Старый 08.08.2017, 03:38   #1
organicax: Setting up an environment to try the PowerBI report models – Part 3
Источник: https://organicax.com/2017/08/07/set...models-part-3/
In the previous post we had a look at refreshing the data in the entity store so we can see the data in PowerBI desktop. The next step if we want to be able to see the data from PowerBI.com is to setup a data gateway between the cloud and your environment. The setup for the data gateway is available from PowerBI.com. The important pieces that we’ll run through in this video is the parameters that are set in the data gateway for the name of the machines, data source, data base in the gateway and in the report model.
It’s important to get the names matched up for the data source and machine name otherwise PowerBI.com won’t be able to fine the data when you try to access the reports online.
D365 July 2017 Update 8 (7.0.4565.16211)
Cheers
Lachlan
Filed under: Business intelligence
organicax: Setting up PowerBI to access your D365 instance. Blog bot DAX Blogs 0 05.11.2016 20:11
axsa: Power BI and Dynamics AX: Part 5: PowerBI.com and On Premise Data (Preview) Blog bot DAX Blogs 0 27.02.2015 15:11
Nav developer: NAV 2009 - Report Designer - Introduction to the new environment Blog bot Dynamics CRM: Blogs 0 15.11.2008 20:21
Часовой пояс GMT +3, время: 23:37.
