Старый 13.09.2017, 17:11   #1
Art Of Creation: SSRS: rsErrorInOnInit error
Источник: http://www.artofcreation.be/2016/10/...noninit-error/
I came across the following error when trying to print a report in Dynamics AX 2012:
Error while setting server report parameters. Error message: An error occurred while executing OnInit: The report execution failed to start. Verify that Report Extensions have been installed or are configured correctly.
Please consult your administrator or the documentation. (rsErrorInOnInit)
I was installing multiple SSRS instances on one server, other instances were working but this particular instance was not.
If you have multiple SSRS instances installed on one server, you have to make sure that the configuration files for all instances are modified correctly.
To solve the above errors, I performed the steps as describe here for the instance that wasn’t working: Modify Reporting Services configuration files [AX 2012]
Art Of Creation: MRP error: Parameters for master plan do not exist Blog bot DAX Blogs 0 13.09.2017 17:11
Art Of Creation: SSRS: Empty fields on report Blog bot DAX Blogs 0 13.09.2017 17:11
kamalblogs: Error: SSRS/EP error when the return type in display method is incorrect – Dynamics AX 2012 Blog bot DAX Blogs 0 11.10.2013 12:11
Часовой пояс GMT +3, время: 17:43.
