Старый 15.03.2018, 04:47   #1
alirazazaidi: Operation could not completed parameter is incorrect D365 for finance and operations.
Источник: https://www.tech.alirazazaidi.com/op...nd-operations/
Aahaaaa, just started development, one table, some edts and a form, as I tried to compile , I found the Error
” Operation could not completed parameter is incorrect”.
[IMG]file:///C:/Users/ALIRAZ~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg[/IMG]
Interestingly, the old trick, run visual studio as administrator still works here.
So I saved the project and run the Visual studio by right click on visual studio Icon and select the run at Administrator.
alirazazaidi: Operation could not completed parameter is incorrect D365 for finance and operations. Blog bot DAX Blogs 0 06.03.2018 04:55
alirazazaidi: Parent child form Customization D365 for Finance and Operations Blog bot DAX Blogs 0 21.01.2018 16:14
alirazazaidi: Custom financial Dimension shows in lookup D365 for Finance and operations Blog bot DAX Blogs 0 14.09.2017 13:11
Часовой пояс GMT +3, время: 16:25.
