Старый 02.11.2018, 14:11   #1
25,644 / 848 (80) +++++++
d365technext: Form Data Source Method override COC D365FO
Источник: http://d365technext.blogspot.com/201...rride-coc.html
Here is the sample how can you override the form data-source event.
In this demo we have created the extension of HcmWorker form data-source (HcmWorker).
Here is the original method of HcmWorker data-source
publicboolean validateWrite()
boolean ret;
ret = super();
if (ret)
partyForm.validateWrite();
return ret;
Here is the code to create form data-source extension class
[ExtensionOf(formdatasourcestr(HcmWorker, HcmWorker))]
finalclassDemo_Extension
Here is the code to override the data-source method through COC.
boolean ret;
ret = next validateWrite();
if (ret)
/// do your code here
return ret;
In last perform Build & Sync.
Important
Feature available from Build 8.1 PU-20
d365technext: Form Data Source Field Method Override D365FO Blog bot DAX Blogs 0 02.11.2018 14:11
ievgensaxblog: D365FOE. How to override form data source field lookup method. Blog bot DAX Blogs 0 10.01.2018 05:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 16:48.
