Старый 13.11.2018, 10:11   #1
butenko.pro: Showing ribbon button based on the result of async operation
Источник: https://butenko.pro/2018/11/13/showi...ync-operation/
Earlier when I had a task to show/hide button based on the result of data-retrieval operation I used following approach – declared variable, made synchronous call to endpoint, set that variable inside the callback and returned true/false result at the end of validation function. It worked but if the operation was long-running it caused blocking ...
Microsoft Dynamics CRM Team Blog: How to Execute a Workflow from a Ribbon Button and Control when the Button is Enabled Blog bot Dynamics CRM: Blogs 0 23.09.2012 06:33
crminthefield: Dynamics CRM 2011 DeletionService Async Maintenance Operation Demystified Blog bot Dynamics CRM: Blogs 0 16.03.2012 00:11
Gareth Tucker: Adding Record Creation Buttons to the CRM 2011 Ribbon Blog bot Dynamics CRM: Blogs 0 12.01.2012 15:11
Gareth Tucker: Adding a new Button Group to the CRM Ribbon Blog bot Dynamics CRM: Blogs 0 24.08.2011 16:11
Часовой пояс GMT +3, время: 01:03.
