Старый 06.02.2019, 07:12   #1
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 2 – Format.
Источник: https://ievgensaxblog.wordpress.com/...part-2-format/
In this blog post we will create new Format. It represents document schema and is used to parse it. Go to Organization administration > Workspaces > Electronic reporting, select Data Model created in the previous post and create new configuration:
In the format designer Add root –> File:
Add sequence and set delimiter to New line – Windows (CR LF). It will tell ER that file has lines split by CR LF. It is possible to select CR for Mac or LF for Linux or specify a custom delimiter.
Add new sequence. This sequence will represent lines. Set Multiplicity to “One many” to say that at least one line is required.
Add another sequence. It will represent individual lines. Set delimiter to ‘,’, to split fields by comma. Use another delimiter, if required.
Add 3 fields:
In the end you should have format like this:
In the next post we will map format to model and test it!
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 4 – Map Model to Datasource. Blog bot DAX Blogs 0 06.02.2019 07:12
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 3 – Map format to model. Blog bot DAX Blogs 0 06.02.2019 07:12
dynamicsax-fico: Electronic Reporting: Import of GL Excel Journals (Part 1) Blog bot DAX Blogs 0 24.01.2019 14:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 01:32.
