#1 |
crmtipoftheday: Tip #1229: Use math to make your chart look good
Источник: https://crmtipoftheday.com/1229/use-...art-look-good/
============== It’s Friday afternoon and the management asked you to create a quick chart illustrating your team’s bug handling pipeline. Easy-peasy. Step 1 – extract data from the Squash-A-Bug system StatusCountNew4268Under Review1921Planned516Completed229Step 2 – visualize it as a small dashboard: That…. does not… look… good… (tried funnel – that’s even worse)We appear to be choking under the flood of new bugs… It’s Friday, for crying out loud, can’t give bad news to the management! (busily searches dusted brain corners for the high education leftovers) Found! Here’s your tip of the day: If your numbers are disproportionally skewed, use the logarithmic scale. It brings the values “closer together” Ahhh, that’s much better. Take that, management!Friday night, here I come! Thank you, Dynamics 365 for the idea (pun intended), and Crissy Jarvis on Unsplash for the cover photo. Источник: https://crmtipoftheday.com/1229/use-...art-look-good/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
