Старый 04.07.2019, 04:09   #1
25,643 / 848 (80) +++++++
sunilrakesh: How to get x++ methods as Microsoft Flow- Action. Example for Submit & Recall workflow. D365FO
Источник: https://community.dynamics.com/ax/b/...orkflow-d365fo
Here is an example on how to create Flow action for x++ methods. I have an requirement from Flow a record(Purchase requisition) want to submit/ Recall workflow. Below steps explain the process.
1. Create custom Data entity.
2. Add new method as shown for SUBMIT.
[SysODataActionAttribute("GetAzureSubmitl", false)]
public static str GetAzureSubmitl(PurchReqId purchReqId )
WorkflowVersionTable workflowVersionTable;
PurchReqTable _purchReqTable;
boolean submited = true;
PurchReqWorkflow purchReqWF;
select _purchReqTable where _purchReqTable.PurchReqId == purchReqId ; // with parameter value string.
workflowVersionTable = Workflow::findWorkflowConfigToActivateForType(workFlowTypeStr(PurchReqReview),
_purchReqTable.RecId,
_purchReqTable.TableId);
if (_purchReqTable.RecId
&& workflowVersionTable.RecId
&& _purchReqTable.RequisitionStatus == PurchReqRequisitionStatus::Draft)
if (PurchReqWFStatusTransitionHelper::setPurchReqTable2InReview(_purchReqTable.RecId))
Workflow::activateFromWorkflowType(workFlowTypeStr(PurchReqReview),
"Submitted",
NoYes::No,
DirPersonUserEx::worker2UserId(_purchReqTable.Originator));
else
submited = false;
3. Save and build you project, you can see your method as an Action in Flow.
sample code for RECALL Purchase requisition workflow.
[SysODataActionAttribute("GetAzureRecall", false)]
public static str GetAzureRecall(PurchReqId purchReqId )
Code for RECALL
WorkflowCorrelationId workflowCorrelationId;
PurchReqTable purchReqTable;
boolean recalled = true;
select purchReqTable where purchReqTable.PurchReqId == purchReqId;//with parameter value string.
if(purchReqTable.RecId != 0 &&
purchReqTable.RequisitionStatus == PurchReqRequisitionStatus::InReview)
PurchReqWFStatusTransitionHelper::setPurchReqTable2Draft(purchReqTable.RecId);
workflowCorrelationId = Workflow::activateFromWorkflowType(workFlowTypeStr(PurchReqReview),
"Recalled by user",
NoYes::No,
DirPersonUserEx::worker2UserId(purchReqTable.Originator));
Workflow::cancelWorkflow(workflowCorrelationId,"Recalled by user");
else
recalled = false;
sertandev: How to integrate D365FO with Microsoft Flow using the new Business Events Blog bot DAX Blogs 0 23.05.2019 16:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
Channel9: Taste of Premier: Microsoft IT Institute - Your Direct Connection to How Microsoft Does IT Blog bot DAX Blogs 0 30.05.2014 02:15
Microsoft Dynamics CRM Team Blog: Update Rollup 5 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 2 27.10.2011 17:11
Microsoft Dynamics CRM Team Blog: Workflow E-mail Utilities Blog bot Dynamics CRM: Blogs 0 16.12.2008 23:05
Часовой пояс GMT +3, время: 18:28.
