Старый 07.10.2019, 16:47   #1
mark_brummel: Tip #62 | “Where-Used” in Visual Studio Code
Источник: https://dynamicsuser.net/nav/b/mark_...al-studio-code
The “Where-Used” in Visual Studio Code is nice, but not always productive. Today I wanted to see where a field was used and came up with an alternative I wanted to share. ObsoleteState If you mark a field ObsoleteState::Pending the compile will throw warnings everywhere the field is used. This allows you to quickly use the error window to jump through the code and check whatever you want to check. When finished you set the obsolete state back. (read more)
mark_brummel: Tip #60 | Suppress Warnings in Visual Studio Code Blog bot NAV: Blogs 0 11.09.2019 18:12
mark_brummel: Tip 59# | Multiple Start Configurations in Visual Studio Code Blog bot NAV: Blogs 0 11.09.2019 18:12
mark_brummel: Say “Hello World” in AL for Visual Studio Code Blog bot NAV: Blogs 0 31.12.2016 00:22
Часовой пояс GMT +3, время: 00:31.
