Старый 26.11.2019, 11:11   #1
ariste.info: Get the T-SQL query from X++
Источник: https://ariste.info/en/2019/11/get-t...-query-from-x/
As you might know MSDyn365FO’s data access layer pretty different from T-SQL. This means that if you copy a query on AX and paste it in SSMS it won’t validate in the 99% of the cases (the other 1% being a select * from table). The differences are specially obvious in the join clauses, for … Continue reading Get the T-SQL query from X++ →
The post Get the T-SQL query from X++ was first published in ariste.info.
ariste.info: Parse XML and JSON easily in MSDyn365FO Blog bot DAX Blogs 0 17.09.2019 16:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1A [Introduction and SQL Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
ошибка при установке outlook плагин для CRM 2011 webmaster Dynamics CRM: Администрирование 8 09.12.2011 12:41
Часовой пояс GMT +3, время: 01:26.
