#1 |
crmtipoftheday: Tip #1369: New user cannot see environment
Источник: https://crmtipoftheday.com/1369/new-...ee-environment
============== I recently saw the following scenario in several environments:
The solution we discovered was that if you have someone with access to the environment share a canvas app in the environment with the user and have the user run the app one time. After that the user will now see the environment, both in maker portal and the admin portal. The Camouflage of an Eastern Bearded Dragon (Pogona barbata) blends almost perfectly with its environment in our cover photo courtesy Andrew Mercer / CC BY-SA Источник: https://crmtipoftheday.com/1369/new-...ee-environment
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
