Старый 24.07.2020, 23:15   #1
msdynamicsworld: From the Microsoft Dynamics 365 Business Central blogs: OData; Page views; Containers; Snippet for AL
Источник: https://msdynamicsworld.com/story/mi...ers-snippet-al
In this week's Dynamics 365 Business Central blog roundup:
  • OData web services: using filter expressions
  • Dynamics 365 Business Central: exploring page views with Azure Application Insights
  • Using Azure Logic Apps to create a Dynamics 365 Business Central container on Azure Container Instances
  • Create snippet for AL in Visual Studio code for D365BC
Writing on his blog, Roberto Stefanetti took a look at the use and properties of OData (Open Data Protocol) with Business Central, which he noted was indispensable if you use the D365BC cloud environment.
Stefanetti first explained exactly what OData is and noted that it builds on certain web technologies to provide access to information from different applications, services, and stores.
OData uses URLs for resource identification and commits to an HTTP-based, uniform interface for interacting with resources.
He then stated that you can use OData web services to show D365BC data as well as update data in a D365BC database and described how to do it.
Finally, he discussed the known limitations of using OData with D365BC.
<h2>Dynamics 365 Business Central: exploring page views with Azure Application Insights
msdynamicsworld: From the Microsoft Dynamics 365 Business Central Blogs: Month end closing; Telemetry; Control add-ins; Stack alerts; Data upgrade problems Blog bot NAV: Blogs 0 27.11.2019 00:22
waldo: Microsoft Dynamics 365 Business Central – 2019 Spring Release Blog bot NAV: Blogs 0 02.04.2019 09:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 22:28.
