Старый 16.09.2020, 06:40   #1
25,644 / 848 (80) +++++++
butenko.pro: JS: How to get the originating record reference in the form script of the Quick Create Form
Источник: https://butenko.pro/2020/09/15/js-ho...k-create-form/
Just imagine that you need to define the context in which “Quick Create Form” was opened and depending on the context – to do some additional operations. In this short post I provide supported code you can use to define it. Create JavaScript webresource and add following code inside: [crayon-5f6189b08c0ab643687662/] Add this webresource to the ...
butenko.pro: How to make 9.0 Classic Client a bit cleaner – 2 Blog bot Dynamics CRM: Blogs 0 08.01.2019 08:13
butenko.pro: How to Retrieve Duplicates using WebApi Blog bot Dynamics CRM: Blogs 0 03.12.2018 11:11
dynamicsaxhints: How to update a caller form when a new record is created in a separate form in AX 2012 Blog bot DAX Blogs 0 31.08.2016 01:13
Gareth Tucker: Quick Create Contact from the Phone Call Form Blog bot Dynamics CRM: Blogs 0 23.08.2011 12:11
casperkamal: Using Script to create code for inserting record in a table Blog bot DAX Blogs 1 13.02.2007 12:57
Часовой пояс GMT +3, время: 10:23.
