Старый 30.10.2020, 15:11   #1
25,644 / 848 (80) +++++++
goshoom: Simple metadata query in Powershell (D365FO)
Источник: http://dev.goshoom.net/en/2020/10/si...rshell-d365fo/
If I need to extra metadata of a D365FO application, my preferred way is the new metadata API. But sometimes the requirement is so simple that it’s sufficient to query source XML files directly.
For example, this all what’s needed to get a list of fields from a table (together with their types) and store it in a CSV file. It’s written in Powershell:
[xml]$xml = Get-Content $inputXmlFilePath$xml.AxTable.Fields.AxTableField | select Name, ExtendedDataType, EnumType | Export-CSV $outputCsvFilePath -nti
It’s great for trivial cases like this. If I needed more details about fields or I had to take into account table extensions, for example, then the metadata API would be a better choice.
d365fo, powershell
littleax: Simple Rest API in D365FO, D365F, D365SCM Blog bot DAX Blogs 0 23.06.2020 14:12
goshoom: Getting service operations from metadata (D365FO) Blog bot DAX Blogs 0 31.05.2019 10:11
goshoom: Find D365FO labels in Powershell Blog bot DAX Blogs 0 28.10.2018 17:11
Microsoft Dynamics CRM Team Blog: New Technical Article: Query Metadata Using JavaScript Blog bot Dynamics CRM: Blogs 0 26.01.2013 02:14
NAV Sustained Engineering Team Blog: Simple query to check the recent performance history II - now including Query Plan information Blog bot Dynamics CRM: Blogs 0 14.10.2008 13:01
Часовой пояс GMT +3, время: 12:09.
