Старый 25.11.2020, 22:12   #1
Alexdmeyer: How to Fix ‘The devInstall option is not applicable to the current deployable package’ Error
Источник: https://alexdmeyer.com/2020/11/25/ho...package-error/
If you are trying to install a deployable package via command line using the AXUpdateInstaller.exe devinstall command like is shown in the Microsoft documentation and get this error: Here are the steps you can take to fix this issue, run the following commands: AXUpdateInstaller.exe generate -runbookid=”OneBoxDev” -topologyfile=”DefaultTopologyData.xml” -servicemodelfile=”DefaultServiceModelData.xml” -runbookfile=”OneBoxDev-runbook.xml” This command generates the runbook that […]
The post How to Fix ‘The devInstall option is not applicable to the current deployable package’ Error appeared first on Alex Meyer.
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
dynamicsaxse: November 2017 Release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 08.12.2017 10:51
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Часовой пояс GMT +3, время: 13:49.
