Старый 26.09.2022, 21:16   #1
25,644 / 848 (80) +++++++
butenko.pro: Applying UCI styling to a FluentUI Dropdown Component
Источник: https://butenko.pro/2022/09/26/apply...own-component/
Here is the next post of the series in regards to styling of FluentUI controls to look native in the UCI interface. Today my post is dedicated to Dropdown control that is now called “Choice” in Dataverse. Let’s compare uncustomized and UCI controls side-by-side in both enabled and disabled states: As you might see there ...
The post Applying UCI styling to a FluentUI Dropdown Component appeared first on Andrew Butenko's Blog.
butenko.pro: Applying UCI Styling to a FluentUI DatePicker component Blog bot Dynamics CRM: Blogs 0 19.09.2022 23:11
butenko.pro: Applying UCI Styling to a FluentUI TextField component Blog bot Dynamics CRM: Blogs 0 14.02.2022 23:17
butenko.pro: JS: Access values of fields located on the “Form Component” PCF Control Blog bot Dynamics CRM: Blogs 0 21.09.2021 06:41
butenko.pro: Open proper form based on record’s data – UCI way Blog bot Dynamics CRM: Blogs 0 14.04.2020 05:20
butenko.pro: Html Webresource, Classic UI vs UCI – story of broken functionality Blog bot Dynamics CRM: Blogs 0 07.12.2018 22:16
Часовой пояс GMT +3, время: 08:08.
