Старый 20.11.2024, 11:11   #1
25,644 / 848 (80) +++++++
goshoom: Run settings for SysTest
Источник: https://dev.goshoom.net/2024/11/run-...s-for-systest/
When you execute automated tests of X++ code with SysTest, the test service (SysTestService class) gets called with some parameters, defined in SysTestRunnerSettings:
You could, for example, set granularity to execute just unit tests and skip integration tests, or produce a trace file for diagnostics.
You may want to use such parameters in automatic processes (e.g. running certain types of tests on gated builds) or directly in Visual Studio.
Visual Studio supports such configuration with .runsettings files (see Configure unit tests by using a .runsettings file). In Visual Studio, you can create a .runsettings file (which is a simple XML file), put it to your solution directory and it’ll be used automatically when running tests from Text Explorer. You can also select a particular file in Test > Configure Run Settings.
I wondered if the same approach can be used for SysTest parameters and it can indeed, you just need to put these parameters into SysTest element (and you must know the correct property names).
</span span class="re0"version/span=span class="st0""1.0"/span span class="re0"encoding/span=span class="st0""utf-8"/spanspan class="re2"?></span> </span> </span>false</span> </span>c:\temp\TestTrace.txt</span> </span></span>
daxmusings: Design-Compile-Run Part2: Design, Compile, Run in AX 2012 Blog bot DAX Blogs 0 04.05.2016 13:11
goshoom: Preview of Release Management Blog bot DAX Blogs 0 15.10.2015 12:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 Fiscal Settings and Goal Management Blog bot Dynamics CRM: Blogs 0 19.01.2011 01:13
Часовой пояс GMT +3, время: 23:18.
