#20 |
Чайный пьяница
Сообщение от Skyway
![]() <Entity name="new_business_trip">
<!-- The Account Tool Bar --> <Grid> <MenuBar> <ActionsMenu> <MenuItem WinMode="1"> <Titles> <Title LCID="1033" Text="тест1" /> </Titles> </MenuItem> </ActionsMenu> <Buttons> <Button Icon="/_imgs/ico_18_debug.gif" JavaScript= "function GetAttributeValueFromID(sEntityName, GUID, sAttributeName) { var authenticationHeader = GenerateAuthenticationHeader(); // Prepare the SOAP message. var xml = ''; xml = xml+'<?xml version='1.0' encoding='utf-8'?>'+ '<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/''+ ' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance''+ ' xmlns:xsd='http://www.w3.org/2001/XMLSchema'>'+ authenticationHeader+ '<soap:Body>'+ '<Retrieve xmlns='http://schemas.microsoft.com/crm/200...s'>'+ '<entityName>'+sEntityName+'</entityName>'+ '<id>'+GUID+'</id>'+ '<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>'+ '<q1:Attributes>'+ '<q1:Attribute>'+sAttributeName+'</q1:Attribute>'+ '</q1:Attributes>'+ '</columnSet>'+ '</Retrieve>'+ '</soap:Body>'+ '</soap:Envelope>'; // Prepare the xmlHttpObject and send the request. var xHReq = new ActiveXObject('Msxml2.XMLHTTP'); xHReq.Open('POST', '/mscrmservices/2007/CrmService.asmx', false); xHReq.setRequestHeader('SOAPAction','http://schemas.microsoft.com/crm/2007/WebServices/Retrieve'); xHReq.setRequestHeader('Content-Type', 'text/xml; charset=utf-8'); xHReq.setRequestHeader('Content-Length', xml.length); xHReq.send(xml); // Capture the result. var resultXml = xHReq.responseXML; // Check for errors. var errorCount = resultXml.selectNodes('//error').length; var result1 = resultXml.selectNodes('//q1:' + sAttributeName).length; if (result1 != 0) { var result = resultXml.selectSingleNode('//q1:' + sAttributeName).nodeTypedValue; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; result = ' '; //alert(msg); } // Display the retrieved value. else { return result; } } } var a = '{07BAE349-C55B-DE11-A2A2-000E0C4BF7BF}'; My_select= GetAttributeValueFromID('account',a,'address1_city'); alert(My_select);" PassParams="0" WinParams="" WinMode="0"> <Titles> <Title LCID="1049" Text="Экспортировать" /> </Titles>
Эмо разработчик, сначала пишу код, потом плачу над его несовершенством. Подписывайтесь на мой блог, twitter и YouTube канал. Пользуйтесь моим Ultimate Workflow Toolkit |
За это сообщение автора поблагодарили: Skyway (1), Tarasov E (1). |
