Старый 11.07.2007, 14:30   #10
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Вот жалкая попытка
static client void izh_internet(Args _args)
    XMLDocument xml;
    str url = "http://www.cbr.ru/scripts/XML_daily.asp?date_req=02/07/2007";
    //str url = "http://theta/mes/WebService?invoke=getBodyTrackInfo&dateTimeFrom=04.07.2007+08%3A33%3A06&dateTimeTo=05.07.2007+08%3A33%3A06&checkPointId=";
    FileIoPermission perm;
    XMLParseError err;
    #File
    System.Net.WebProxy proxy = System.Net.WebProxy::GetDefaultProxy();
    Object req1 = System.Net.WebRequest::Create(url);
    System.Net.HttpWebRequest req = req1;
    CLRObject reader;
    System.Net.HttpWebResponse response;
    System.IO.Stream dataStream;
    str asXML;
    info('test');
    req.set_Proxy(System.Net.WebProxy::GetDefaultProxy());
    xml = new XMLDocument();
    response = req.GetResponse();
    dataStream = response.GetResponseStream();
    //reader = new System.IO.StreamReader(dataStream);
    reader = new CLRObject('System.IO.StreamReader', dataStream);
    asXML = reader.readToEnd();
    info (asXML);
    CodeAccessPermission::revertAssert();
    perm = new FileIoPermission(url, #io_read);
    perm.assert();
    xml.loadXml(asXML);
    err = xml.parseError();
    info(err.toString());
    info(xml.xml());
документация, ax3.0, ax4.0
Закачка файлов из интернета через proxy в 4.0 trud DAX: Программирование 4 18.12.2013 18:16
Dianne Siebold: Rec Fields Required in AIF Partial Update Blog bot DAX Blogs 0 20.01.2009 09:05
Using Windows Integrated Authentication with IIS-hosted Dynamics AX Services Blog bot DAX Blogs 0 13.12.2008 08:06
AX UK: AX 2009 Presales workshop - Wednesday 11th, install required Blog bot DAX Blogs 0 08.12.2008 22:05
Solutions Monkey: Forms Based Authentication ( FBA) in WSS 3.0 / MOSS 2007 Blog bot DAX Blogs 0 28.08.2007 04:11
Часовой пояс GMT +3, время: 02:16.
