Старый 09.10.2007, 13:24   #4
zhenek is offline
zhenek
The following table contains additional information about form types.
Form Form type value Description
Undefined 0 For internal use only.
Create 1 This is the main form for an entity, displayed with blank values when creating an entity instance.
Update 2 This is the main form for an entity, displayed with the current values for the entity instance being updated.
Read only 3 This is the main form for an entity, displayed with the current values for the entity instance. All fields are disabled. This is used when the user does not have privileges or acess rights to edit the entity instance.
Disabled 4 This is the main form for an entity, displayed with the current values for the entity instance. All fields are disabled. This is used when the entity instance is in the Inactive state.
Quick create 5 This form is accessible from the lookup dialog. It is not available for custom entities. It contains the minimum fields needed to create an entity instance.
Bulk edit 6 This form is used for editing multiple instances at a time.
Последний раз редактировалось zhenek; 09.10.2007 в 13:28.
Событие "Назначение записи" для бизнес-процесса Lazarus Dynamics CRM: Функционал 1 22.01.2009 19:54
Как можно подписаться на событие завершения и отмены заказа? homer12 Dynamics CRM: Разработка 2 04.12.2008 18:10
Не вызывается OnLoad() heon Dynamics CRM: Разработка 3 23.09.2008 22:22
Сделать активным поле из onLoad tatra Dynamics CRM: Разработка 1 01.11.2007 09:24
событие Update object в workflow shumelka Dynamics CRM: Функционал 1 18.03.2005 11:39
Часовой пояс GMT +3, время: 05:05.
