Старый 11.08.2008, 14:41   #4
egorych is offline
egorych
Oracle
761 / 154 (7) ++++++
Сообщение от CasperSKY Посмотреть сообщение
"The peer prematurely closed the connection." - с чем может быть связана ?
Может это поможет - http://forums.microsoft.com/TechNet/...9362&SiteID=17
SSAS does not support SQL logins so this will not work. It only supports windows logins and your login would either need to be in the server administrators role (where you would be able to see everything) or your login would need to be added to a role in the database with rights to see specific cube.
This article has information on resolving connection issues. http://www.microsoft.com/technet/pro...L2005ASCS.mspx but you get the "transport layer" issue when trying to connect from a non trusted domain.
ax4.0
Переход от 2000 к 2005 omakondo DAX: Администрирование 3 07.10.2008 10:33
C# and AX Development: Configuring Analysis Services 2005 for AX Blog bot DAX Blogs 0 04.08.2008 03:16
Переход на SQL 2005 Lucky13 DAX: Администрирование 13 03.12.2007 18:01
Переход на SQL SERVER 2005 - есть ли смысл и безопасно ли? Rage DAX: Администрирование 16 17.06.2007 17:31
Axapta 3.0 и Analysis Server 2005 Spider DAX: Администрирование 9 20.12.2006 07:09
Часовой пояс GMT +3, время: 03:19.
