Старый 24.06.2009, 16:00   #5
alsherin is offline
alsherin
>MSCRM Error Report:
Error: There is already an object named 'new_objectname' in the database.
Could not create constraint. See previous errors.
Error Message: There is already an object named 'new_objectname' in the database.
Source File: Not available
Line Number: Not available
Request URL: http://localhots:5555/Organization-C...omization.asmx
Stack Trace Info: [SqlException: There is already an object named 'new_objectname' in the database.
Could not create constraint. See previous errors.]
в System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
в System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
в System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
в System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async)
в System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe)
в System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
в Microsoft.Crm.CrmDbConnection.InternalExecuteNonQuery(IDbCommand command)
в Microsoft.Crm.CrmDbConnection.ExecuteNonQuery(IDbCommand command, Boolean impersonate)
в Microsoft.Crm.Metadata.SqlHelper.ExecuteNonQuery(MetadataHelper helper, IDbCommand sqlCommand)
в Microsoft.Crm.Metadata.RelationshipCreateAction.DatabaseOperation()
в Microsoft.Crm.Metadata.MetadataHelper.ProcessQueue()
в Microsoft.Crm.Metadata.RelationshipServiceBase.Create(IRelationshipCreateInfo relationshipInfo, ExecutionContext context)
в Microsoft.Crm.Metadata.RelationshipServiceBase.Create(IRelationshipCreateInfo createInfo)
в Microsoft.Crm.Metadata.EntityRelationshipService.Create(IRelationshipCreateInfo relationshipInfo)
в Microsoft.Crm.Application.WebServices.SystemCustomization.RelationshipCreate.Execute(IUser user, ParameterBag paramBag)
в Microsoft.Crm.Application.WebServices.SystemCustomization.SystemCustomization.CreateRelationship(XmlNode data)
ошибка 500 при создании и авторизации пользователя из домена Dr.Melkiades Dynamics CRM: Администрирование 5 16.06.2009 08:22
Ошибка при создании отчетов в CRM 4.0 Yuki Dynamics CRM: Администрирование 27 19.05.2009 11:26
Ошибка в плагине при создании связей N:N SJK Dynamics CRM: Разработка 4 18.03.2009 20:19
При создании сопоставления выдетает ошибка! pkost Dynamics CRM: Разработка 3 03.07.2008 21:01
Ошибка при создании веб-ссылки в MS VS? Alexey-IT Dynamics CRM: Разработка 1 12.01.2008 03:24
Часовой пояс GMT +3, время: 19:09.
