Старый 17.11.2010, 04:12   #1
25,644 / 848 (80) +++++++
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 6 has been released to Partner Source and Customer Source
Источник: http://blogs.technet.com/b/dynamicsa...er-source.aspx
Today, we're happy to announce to release of Dynamics AX 2009 Rollup 6 for RTM and SP1 customers. These releases are available on Partner Source and Customer Source.
Due to the cumulative nature of the rollups, RU-6 carries all the content that has been released in previous rollups (RU-1, RU-2, RU-3, RU-4, RU-5).
For more information, please refer to the following knowledge base articles:
Старый 17.11.2010, 11:25   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post
Прямые линки на закачку:
P.S. Скачать hotfix с PartnerSource
This posting is provided "AS IS" with no warranties, and confers no rights.
Последний раз редактировалось Poleax; 17.11.2010 в 11:42.
Старый 17.11.2010, 16:46   #3
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Я так понимаю, описание для России опять доступно только партнерам. Наверное, стоит выложить его в тему Документация для Rollup'ов и Whats News.. Кстати, она вроде бы была в разделе "Полезное" на главной странице?
Ivanhoe as is..
Старый 17.11.2010, 20:54   #4
Logger is offline
Logger
3,987 / 3273 (117) ++++++++++
Записей в блоге: 2
Почитал описание исправленных багов.
Нашел 5 упоминаний про падение АОСа.
2268240 The Application Object Server (AOS) crashes when the user rights are reloaded in Microsoft Dynamics X 2009 Service Pack 1
2278252 The Application Object Server (AOS) crashes when you select companies during the creation of a custom report in Microsoft Dynamics AX 2009
2279750 Multiple Application Object Servers crash when you use Microsoft Dynamics AX 2009
2286464 The Application Object Server (AOS) server and the client crash when temporary tables are used in the X++ insert_recordset operation in Microsoft Dynamics AX 2009 Service Pack 1
2310307 The AOS instance crashes randomly.
Грустно как-то.
Кто работает на 2009-й, как ощущения ? Аос реально падучий или это экзотические случаи ?
В 3-ке мне 1 раз только удалось его свалить.
Старый 17.11.2010, 22:21   #5
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Нормально AOS работает. В RU5 фиксили косяк с регулярным падением AOS-а при печати отчетов (мы такое ловили на буржуйском sales invoice). Теперь наверное стал еще надежнее
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: Logger (2).
Старый 17.11.2010, 22:24   #6
Logger is offline
Logger
Записей в блоге: 2
Спасибо.
А я на обработке фактур ловил и еще где-то. Тоже на RU5
Старый 18.11.2010, 14:06   #7
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
У нас АОС ru5 - полет нормальный.
Хотя что бы положить АОС многими знаниями обладать не нужно (я про кастомные доработки)
Axapta book for developer
Старый 19.11.2010, 12:12   #8
oleg_e is offline
oleg_e
Thumbs up
Так как насчет российского описания Rollup5? Может перепадет с "Барского стола"?
Старый 19.11.2010, 14:33   #9
oleg_e is offline
oleg_e
Поправка - Rollup6
Старый 19.11.2010, 16:09   #10
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Ivanhoe as is..
Старый 19.11.2010, 17:54   #11
Bega is offline
Bega
Аватар для Bega
382 / 444 (15) +++++++
Накатил RU6 на DAX2009 SP1 RU5, обнаружил, что не обновились файлы (и версии) gls и glp. Решил еще раз накатить, полностью вернул старое приложение и базу данных, запускаю установку, однако она уже не предлагает к обновлению это приложение. Проверил версии файлов *.version, они все от 5-го роллапа, не понимаю, что теперь не нравится установщику.
Старый 21.11.2010, 23:40   #12
Сообщение от Bega Посмотреть сообщение
ax2009 cu5: кто-нибудь понял по какому алгоритму оно обновляет?
Старый 23.11.2010, 12:46   #13
Kabardian is offline
Kabardian
Талантливый разгвоздяй
Аватар для Kabardian
424 / 338 (12) ++++++
Записей в блоге: 14
RU6 не накатывается на AX2009 SP1 EE + GSL RU + HRP SL2
Кто-нибудь накатывал Rollup 6 сразу на AX 2009 SP1 EE + GLS RU + HRP SL2?
В чек-листе обновления, застрял на шаге Data upgrade / Postsynchronize (обновление данных после синхронизации). Пакетная обработка обновления данных не запускается . Кто виноват? Что делать?
На этой системе импортированы демо-данные буржуйские и российские в 6 разных компаниях, но не думаю, что это имеет какое-то значение.
Старый 23.11.2010, 13:04   #14
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
Сообщение от Kabardian Посмотреть сообщение
Может HRP SL2 мешает? Компиляция, что показала?
Human Resource Management and Payroll for Microsoft Dynamics AX 2009 (Russia)
https://mbs.microsoft.com/partnersou...alse&stext=HRP
https://mbs.microsoft.com/customerso...alse&stext=HRP
от 27-Jul-10 заточен под Hotfix Rollup 5
под Rollup 6 обновление HRP ожидается.
За это сообщение автора поблагодарили: Kabardian (3).
Старый 23.11.2010, 15:13   #15
Kabardian
Записей в блоге: 14
Сообщение от Poleax Посмотреть сообщение
Спасибо за наводки, буду разбираться. Как появится какой-нибудь результат обязательно сообщу .
А пока вот что я нашел:
Troubleshooting the Data upgrade cockpit
http://technet.microsoft.com/en-us/l.../dd309696.aspx
Upgrade job fails to start
Issue: The upgrade job doesn't start after clicking the Run or Trial Run buttons in the Data upgrade cockpit and all upgrade scripts remain in the Ready state for a long time.
<вырезано цензурой>
Possible cause #2: The batch server defined for running the upgrade job is not running.
Solution: Open the Server configuration form (Administration > Setup > Server configuration). Verify that Is Batch Server is marked for the AOS instance that is running the upgrade.
И в самом деле у меня для пакетной группы Data updgrade не был выбран АОС. Честно говоря, такой засады я просто не ожидал -- даже на "древней" AX 4.0 джобы по обновлению данных после апгрейда запускались при любом раскладе .
upd: получилось, проблема была в настройках пакетной обработки.
Последний раз редактировалось Kabardian; 23.11.2010 в 16:18.
За это сообщение автора поблагодарили: Кирен (1).
Старый 24.11.2010, 10:40   #16
Daiver is offline
Daiver
177 / 44 (2) +++
Проблема с таблицей SysDataBaseLog. Не возможно вставтить запись. Система ругается "Object Server 02: The database reported (session 3 (Admin)): [Microsoft][SQL Native Client][SQL Server]Недопустимое имя столбца "createddate".. "
На RU5 такого не замечено.
DAX 2009 SP1 RU6
Kernel 5.0.1500.3761
Application 5.0.1500.3761
Location Eastern Europe
Старый 24.11.2010, 11:16   #17
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Синхронизация таблиц не помогает?
Ivanhoe as is..
Старый 24.11.2010, 11:21   #18
Vadik is offline
Vadik
Аватар для Vadik
Сообщение от Daiver Посмотреть сообщение
А должно быть CreatedDateTime - опечатка ?
-ТСЯ или -ТЬСЯ ?
Старый 24.11.2010, 12:34   #19
Daiver is offline
Daiver
177 / 44 (2) +++
Не помогает. В таблице поле CreatedDateTime, а вот ядро (наверное) ищет поле createddate.
Пробовал DoInsert-том добавлять запись, та же ошибка. Посмотрел системные таблицы, там все корректно для этой таблицы.
Ну да, должно заполнятся поле CreatedDateTime, а система зачемто пытается записать в поле createddate которого уже нету.
Старый 24.11.2010, 12:48   #20
Vadik is offline
Vadik
Аватар для Vadik
Повод проверить содержимое SQLDICTIONARY
-ТСЯ или -ТЬСЯ ?
ax2009, rollup, ru6, полезное
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 5 has been released to Partner Source and Customer Source Blog bot DAX Blogs 3 01.07.2010 11:01
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 4 has been released to Partner Source and Customer Source Blog bot DAX Blogs 13 15.04.2010 09:29
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 3 has been released to Partner Source and Customer Source Blog bot DAX Blogs 0 01.10.2009 10:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 2 is available on Partner Source and Customer Source! Blog bot DAX Blogs 0 10.07.2009 10:05
Часовой пояс GMT +3, время: 05:03.
