#18 |
Сообщение от Владимир Максимов
Нет. Мне нужны не "общие слова", а именно те два простых правила, которые я и привел как тот принцип, по которому работают участники данной темы.
Approaches to Granting Security
There are a few things to consider when approaching security. For some it is best to begin with the highest permissions level and restrict access to specific objects. For others, it is best to begin with the lowest level and grant access to objects. The best approach may vary for each user group. The advantage to starting will the highest level and then restricting specific objects is that it leaves permission granted to the parent keys, such as the “Accounts Receivable” key. On its own, this key grants nothing to a user that they can see in the application, but for some operations the inherited pieces may be necessary. Alternatively, starting with the least access and granting has the advantage of keeping the application as locked down as possible. The disadvantage here is that when a parent key is needed, it must be turned on. This will grant access to all child keys. This means that you must go back and restrict access again, and essentially doubles the effort in a case that the need for a parent key is found. ...
Ivanhoe as is.. |
| Теги |
| ax2009, security, securitykey, как правильно, права доступа |
