Старый 13.05.2011, 15:08   #8
Сообщение от Katuxa Посмотреть сообщение
К сожалению Blogger в данный момент недоступен .
Читать вроде можно.
This Blog Linked From Here Related links (DAX blogs, communities, etc)
This Blog
Linked From Here
.Related links (DAX blogs, communities, etc)
Monday, June 25, 2007
3 Dialog extensions
Performing one of the modifications on the project I am currently working on, I had to modify the behavior of one of the basic classes using the RunBase framework.
Anyway, what I needed to do was:
1.Override the basic lookup for a specific control on the dialog.
2.Prevent user interaction with other forms until the dialog is closed.
3.Make some of the controls in the dialog mandatory.
Well, the perfect solution here would be to create a Form, and use it as the dialog.
But the code was very highly customized, so it would be a hard job.
So I decided to go another way, using what I have on hand, and that is the Dialog class.
For that, I needed a couple of modifications to the Dialog class, as it does not allow any of the 3 features I neded.
But what any developer should clearly understand when using dialogs is - this is just another form. Simple as that - Dialog is just another AOT form. What this means is that with a dialog we can do all the things we can do with a form.
Also, which is very nice and I thank DAX Developers for that, RunBase framework uses DialogRunBase class for showing forms, and this class is extending from class Dialog, so changes made to Dialog will also be available in RunBase framework.
Here is a small explanation of what has been modified:
•Added a class Dialog variable showModal, which controls the modal state of the used dialog.
•Added a parm method to set the value of the showModal variable. So, basically, to make a modal dialog you simply have to call this method passing true as the parameter.
•Added a method SetFormModal, which actually does all the enabling/disabling of windows (DAX 3.0 only, as DAX 4.0 already has built-in modal forms)
•Modified runOnClient() method to allow server dialogs to run modal as well
•Modified wait() method, which calls SetFormModal method (DAX 3.0 only)
•AddField and AddFieldd modified to allow specifying a specific name for a control.
•DialogField class was modified to allow setting the mandatory property (mandatory(), unpack() methods) and specifying a specific name for a control (new and fieldname methods)
The project contains 4 objects:
•Class\Dialog - only modified methods
•Class\DialogField - only modified methods
•Class\Tutorial_RunBaseForm
•Jobs\tutorial_DialogModalMandatory
The tutorials show the features added to the Dialog and DialogField classes (one of them is present in the basic application and is extending from RunBase, using an AOT form, the second is a job, showing the use of Dialog class)
DAX 3.0 Download link (was created in DAX 3.0 SP5 KR2) - DOWNLOAD
DAX 4.0 Download link (was created in DAX 4.0 SP1 EE) - DOWNLOAD
Important:
After importing the project do not forget to compile forward the Dialog class and to restart the DAX client.
Certain Issues you should know about:
1.InfoActions, if present, will allow to access forms, if the infolog window with them was opened before the modal dialog was called.
2.Mandatory property starts working only after a value is entered into the control. What this means is that if you simply press OK right after the dialog is opened, you won't receive an error (regular forms works this way too)
Credits
The modification allowing to specify a specific name for a DialogField was originally posted on the Russian Axapta forum
(Не)перерисовка окна клиента AX 2009 при длительных операциях - вариант решения gl00mie DAX: Программирование 12 27.02.2019 15:03
Событие(я) при активизации окна Workspace HorrR DAX: Программирование 5 28.09.2009 17:27
Как изменить заголовок окна предв.просмотра отчета Владимир Максимов DAX: Программирование 6 03.07.2006 15:34
Как убрать кнопку закрытия окна у диалога? Romb DAX: База знаний и проекты 5 15.02.2006 11:41
Как получить размер окна и клиентской области? gudzon DAX: Программирование 15 15.09.2005 15:15
Часовой пояс GMT +3, время: 15:08.
