Старый 01.04.2017, 02:17   #1
25,644 / 848 (80) +++++++
organicax: Estimated vs Realized costs for a production order
Источник: https://organicax.com/2017/03/31/est...duction-order/
When you produce goods you usually want to analyze the costs. Usually you will have a budgeted costs or estimated costs and then actual costs when you finish the production. It’s helpful to them look at variances to see why something costs less/more than you expected. Costs could vary based on materials, labor, direct or indirect costs and overhead applied to the production. In this overview let’s first have a look at the basic process of how you can generate an estimate cost and see the difference between actual after you finished the production.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: cXML Purchase Order Request Send AX2012 R3 V1 Blog bot DAX Blogs 0 09.02.2017 16:11
organicax: Operation relations and the production order route Blog bot DAX Blogs 0 17.10.2016 23:11
organicax: WMS Mobile device menu – Start production order Blog bot DAX Blogs 0 01.09.2016 01:18
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 18:53.
