Старый 10.01.2007, 17:10   #1
casperkamal: Data XML Generation Wizard
Источник: http://casperkamal.spaces.live.com/B...CD63!200.entry
         I have developed a small wizard for the first time. As the name describes u can use this Wizard to generate XML for any table.
 This wizard comes with the following features………
  1. You can customize and choose the fields that you want in the xml
  2. You can specify a query which will govern the data to be sent in the xml.
  3.  A schema file is generated that displays the data generated in the form of tables and not as normal XMLs.
  4. Fields that are at system level or visible property is set to “No” are not allowed in the xml.
  5. All mandatory fields are always included in the xml.
  6.  The XML and style sheet gets saved in “C:\”
Complete detail of the wizard, screen shots and XPO are available in Axaptapedia under the following link
 http://www.axaptapedia.com/Data_XML_Generation_wizard
 ..............................more features to come
Dynamics AX FAQ: How to import and export data in XML format using Axd classes? Blog bot DAX Blogs 0 04.03.2008 06:13
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Inside Dynamics AX 4.0: Wizard Framework Extension Part II Blog bot DAX Blogs 0 29.09.2007 19:00
casperkamal: XML Notepad - An Interesting utility for editing XML Blog bot DAX Blogs 0 30.06.2007 20:03
casperkamal: Data XML Generation Wizard - Version 2.0 For Dynamics Ax Blog bot DAX Blogs 0 04.03.2007 23:04
Часовой пояс GMT +3, время: 09:04.
