Старый 04.03.2007, 23:04   #1
casperkamal: Data XML Generation Wizard - Version 2.0 For Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!247.entry
Data XMLGeneration Wizard Release 2.0
Newer version of "Data XML Generation wizard" is now available from Axaptapedia.com
New Features :
 1. Table fields to be exported can now be mapped to a different name
     For E.x: Custable.name -> custable.customername
     so the XML tag would be
     instead of the actual
 2. You can specify the location where the XML's generated is to be stored
 3. The XML Generated is displayed inside Ax immediately after closing the wizard,
     through XML Viewer
 4. There is a small addon called the XML Viewer which is being used to display the XML's
     you can use that for displaying your html files or xml files just by passing the path
     as argument to it.
Click here to download the file from Axaptapedia.com
http://www.axaptapedia.com/Data_XML_Generation_wizard
Click here to view older versions blog entry
http://casperkamal.spaces.live.com/b...CD63!200.entry
Your suggestions, feedback anything over this is most welcome ....
.................Keep watching more tools to come up
Dynamics AX FAQ: How to import and export data in XML format using Axd classes? Blog bot DAX Blogs 0 04.03.2008 06:13
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Inside Dynamics AX 4.0: Wizard Framework Extension Part II Blog bot DAX Blogs 0 29.09.2007 19:00
casperkamal: Data XML Generation Wizard Blog bot DAX Blogs 0 10.01.2007 17:10
Часовой пояс GMT +3, время: 07:43.
