Старый 09.09.2008, 17:05   #1
msdynamicsax: Hide the content pane in Ax 2009
Источник: http://msdynamicsax.wordpress.com/20...ne-in-ax-2009/
Have you ever noticed that you can’t press the x of the content pane in Ax 2009 in order to close it when you are in development mode?
Well…here’s a little job that hides it (and shows it again when needed)
static void hideContentPane(Args _args)
    #WinApi
    HWND contentPane =  WinApi::findWindowEx(WinAPI::findWindowEx(infolog.hWnd(), 0, ‘MDIClient’, ”),0,’ContentFrame’,” );
    if (contentPane)
        WinApi::ShowWindow(contentPane, #SW_HIDE);
        //Change to #SW_SHOWNORMAL when you want it back
интерфейс, ax2009
msdynamicsax: Dynamics Ax 2009 SDK Blog bot DAX Blogs 0 13.08.2008 14:05
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
axcoder: How to hide Content Pane in Ax 2009 Blog bot DAX Blogs 0 02.07.2008 00:07
Часовой пояс GMT +3, время: 00:02.
