Старый 23.08.2011, 19:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Retail Store Connect: Item cannot be found in the collection corresponding to the requested name or ordinal
Источник: http://blogs.msdn.com/b/emeadaxsuppo...r-ordinal.aspx
Issue:
Item cannot be found in the collection corresponding to the requested name or ordinal., table 'RBOSTAFFTABLE': 5637146104,0,0,0,0,0,0,0,0,0,0,,ceu,84374,,0,John,Doe,,1,30,0,0,0,40,0,Admin,4/13/2010 6:57:01 PM,John Evans,JohnE,0758441cBD8C3CE1,PoljiTh
Cause:
The issue is that the schema of the AxRetailPOS database if not matching the columns that is in the package file
The reason is that the version of the POS is not matching the HQ application
Example having R2 Refresh(5.0.1506.1032) in the HQ, but the POS.exe is R1 release (5.0.1506.130)
Solution:
Install a matching system with the same build
Author: Kim
Editor: Kim
Date: 23. August 2011
emeadaxsupport: Store connect - IDispatch error #3119: Violation of PRIMARY KEY Blog bot DAX Blogs 0 18.08.2011 18:11
emeadaxsupport: Store Connect: error “Multiple-step operation generated errors” Blog bot DAX Blogs 0 18.08.2011 18:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
dynamicsaxtraining: Item setup: Item group Blog bot DAX Blogs 0 12.11.2009 17:05
Часовой пояс GMT +3, время: 22:47.
