Старый 10.11.2012, 02:16   #1
25,644 / 848 (80) +++++++
ax_gfm_framework_team: Batch processing for dimension set balance rebuilds
Источник: http://blogs.msdn.com/b/ax_gfm_frame...-rebuilds.aspx
When performing dimension set balance rebuilds in a batch, be sure to schedule the batches far enough apart that they do not run concurrently. Doing this will eliminate any chance for contention since a rebuild has to process the entire general journal.
Dimension set balance updates are optimized to run efficiently even if they run concurrently,
ax_gfm_framework_team: Integrating a Source Document with Budget Control Blog bot DAX Blogs 0 18.07.2012 00:11
ax_gfm_framework_team: Step 3: Perform initial wiring to Source Document Framework – document classes Blog bot DAX Blogs 0 01.05.2012 18:11
ax_gfm_framework_team: Step 2: Perform initial wiring to Source Document Framework – tables and maps Blog bot DAX Blogs 0 28.04.2012 10:11
ax_gfm_framework_team: Extending the Source Document Framework Blog bot DAX Blogs 0 28.04.2012 10:11
Часовой пояс GMT +3, время: 22:09.
