Старый 05.06.2014, 15:11   #1
atinkerersnotebook: Create Open Ended Filters By Using Ranges With No Beginning Or End
Источник: http://atinkerersnotebook.com/2014/0...inning-or-end/
Originally posted on Dynamics AX Tip Of The Day:
Everyone knows that you can use the “..” to search for ranges of records when you filter out your data, but it becomes even more useful when you skip either the beginning or end filter selection because then you can create a filter for everything before, or everything after a certain value.
It’s like creating your own version of the Neverending (or Neverbegginning ) story.
View original 59 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 13:23.
