Старый 26.05.2015, 17:11   #1
emeadaxsupport: Fields fetch behavior for "EntireTable" cache table
Источник: http://blogs.msdn.com/b/axsupport/ar...ble-cache.aspx
The CacheLookup property of the table defines how and
when records are cached. The below definition is valid for the “EntireTable” cache type:
EntireTable
Creates a set-based cache on the server. The entire table is cached as
soon as at least one record is selected from the table.
So, if the table “CacheLookup” property is set to “EntireTable” cache, the system
will always fetch all fields, irrespective of the field list provided in the code.
It’s therefore, the Developer (who writes the code) responsibility to make sure
to add all required fields to the field list in his code, regardless the table “CacheLookup” property.
This is in order to avoid any integrity issues, if the table “CacheLookup” property, later on,
is changed to something else by somebody else.
emeadaxsupport: Dynamics AX Table Caching: Basic Rules Blog bot DAX Blogs 0 21.02.2015 10:16
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 6 Blog bot DAX Blogs 0 01.09.2014 14:11
emeadaxsupport: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId". The conflict occurred in database "YourDataBaseName_model", table "dbo.Model" Blog bot DAX Blogs 0 23.05.2014 13:11
emeadaxsupport: Updating index fields while fetching data from the table using the same index can result in the same row being fetched twice Blog bot DAX Blogs 1 21.10.2013 22:45
emeadaxsupport: AX for Retail 2012 R2: Working with Custom Fields for Receipts Blog bot DAX Blogs 0 16.02.2013 23:12
Часовой пояс GMT +3, время: 18:33.
